how do I import svg files to LB
[image]
[image]
I think you mean SVG?
Click on ‘LightBurn files’ when opening the file to switch to ‘All supported’:
Thx Jess
But…
If I have made it in Inventables Easel how do I do then.
All the projects I have made are saved at Inventables
Kristian / Sweden
any one else have a hint PLEASE
Apparently you must export the design:
Unzip that file and it should have an SVG file inside, although Windows will helpfully hide the SVG extension and probably offer to open it with a web browser.
In LightBurn, use Edit → Import and select that SVG file:
You may need to adjust the SVG dots-per-inch value to match whatever Easel uses:
The choices are 72 and 96 DPI, so if the resulting artwork isn’t the correct size, then select the other value.
