SVG Import, lightburn ignoring polyline objects
Hello
i wanted to import a design i exported from my PCB EDA software as SVG
on closer inspection it contains 3 different object types. <rect <polyline and <circle.
rect and circle work fine but it wont import polylines at all
a example svg file with just a polyline inside:
test
its code looks like this (had to remove all < symbols otherwise the text wouldnt be visible…?!)
	svg xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" width="35.103mm" height="61.976mm" viewBox="4009.9 3475 138.2 244">
	title>/title>
	style type="text/css">
		*[layerid="1"] {stroke:#000000;fill:#000000;}
		*[fill="none"] {fill: none;}
		*[stroke="none"] {stroke: none;}
		path, polyline, polygon, line {stroke-linecap:round;}
	/style>
	polyline points="4043.445 3629.1922 4043.445 3639.055 4041.5 3641 4036.9568 3641" stroke-width="4"  stroke-linecap="round" fill="none" layerid="1" net="GND" id="gge2008" locked="0" />
/svg>
the svg should look like this (zoomed in)
grafik
but nothing gets imported into lightburn at all.
when i add another object like rect or circle to the code, it only imports that piece, nothing else.
please add polyline support to svg import.
As a workaround, open the file in Inkscape, select the shape(s) and then
Path>Stroke to Path
Save and import SVG into LB
@RalphU just beat me to it!!
That worked like a charm, thank you very much.
