Hello.
I use plugin for CorelDraw to export vector image into svg file directly to Lightburn. During idling laser also burn.
In what is the problem? In machine preferences - GRBL laser
Laser - chinese vigotec vg l7 ( https://aliexpress.ru/item/4000329778323.html ), 20 W, power during burning 10-12%, speed 2500 mm/min
Read here:
May be I didn’t exact situation. This problem exist only during import files from CorelDraw to svg format. With own graphic in Lightburn and with as example jpg files laser work correctly.
Anyway. thank you for solution, I will try it at evening and check how it work.
Yes, you answer help me. Thank a lot
