I have some fancy svg’s made with adobe illustrator. I am using Lightburn Galvo. So import them and they show up as a image
Is it possible you’re exporting to an image format and not actually SVG? Try opening in a text editor. SVG should be plain text and readable. Image formats will not be.
Looks like Illustrator is embedding a JPEG image within the SVG file rather than retaining vector data.
Could it be how you’re exporting the SVG? Have you tried importing the .AI file directly into LightBurn?
Whatever you think you got, it isn’t an svg file.
Svg files do not contain grayscale, so it is an image file.
Does the filename have a .svg extension?
I though you could ‘drag and drop’ it from AI… ?
Note that SVG files themselves are perfectly capable of containing grayscale. However, LightBurn does not retain/display that information for its purposes.
So I upload a adobe .ai file and same thing happened.
I don’t have $$$ right now to get them done again
Thank you for all your help
These were commissioned files? If that’s the case then you didn’t get what you thought you were getting with the files. Sounds like you got an AI file containing a raster image rather than the base vector drawing data.
Can you connect with the designer and confirm or get them to send you the actual core vector data?
