I’ve got an issue where an SVG is showing up great in inkscape or internet explorer, but when I pull it into lighburn, it doesn’t. Anyone know what to do to fix this? Is there a format I can export in that might work better?
I’m going to be cutting the lines and rastering the images.
SVG’s work great in LightBurn. I suspect the image editing you did to create this work in your external tools is a “masking” and not a true crop. It is a virtual crop used by these programs to allow the image to stay unaltered and still available in its original form. You should “flatten” these or use a true corp tool prior to exporting as SVG and they will import as expected.
Rick is correct - LightBurn doesn’t support masks yet. Can I ask you to forward me this file, or a simple version of it with a single one of those cropped images and the hexagon? It’ll make a good reference for implementing the feature.
