SVG text imports into Lightburn without underlined and Italic attributes. (works ok on Adobe Illustrator and Corel Draw)
Hi,
I have several SVG files that contain text, and the text is underlined, bold and italic.
However, when I input the svg files into Lightburn, the text is Bold, but it is not underlined nor italic.
How can I fix this?
When I input the same svg files into Adobe Illustrator and Corel Draw, the text looks ok.
I am attaching a very simplified svg file with the proper attributes, and pictures of the imported text in Lightburn, Corel Draw and Adobe Illustrator.
Thank you,
Marco.
This is the SVG content:
Bold, Italic and Underlined Text
<svg viewBox="0 0 350 50" xmlns="http://www.w3.org/2000/svg">
  <text x="10" y="30"
        font-family="sans-serif"
        font-size="20"
        font-style="italic"
		font-weight="bold"
        text-decoration="underline">
  </text>
</svg>
Sorry, I cannot add the whole SVG text, but the SVG file is attached.
Thank you.
Is this SVG text import a known Lightburn issue?
Is there a workaround?
Thank you.
Select the font and “create outlines” in Illustrator, then export a new SVG, or if you are in CorelDraw, select the font and “convert to curves”, then export a new SVG.
Note that you won’t be able to edit the font in Lightburn, because it will now be shapes.
Ralph,
thanks for your response.
I am running several laser engravers on a production line, where an SVG generator takes the information from customers via an internet app and provides the SVG file to the production floor. to engrave the product. The requirement is that the file should not be manipulated; instead just received and input into Lightburn and sent to engrave. The generated file currently has the right dimensions, and maps to the appropriate layers, so all the operators have to do is place it into the template and send to engrave.
It has been working ok, until we just last week implemented the ability for the customers to use underlined and italic text.
For some reason, Lightburn does not import SVG text that is italic nor underlined. Every other software i have tried does, Adobe Illustrator, Corel Draw, Inkscape,etc, But I have not found a way to get Lightburn to accept italic and/or underlined text.
I would rather not have the operators manipulate the files, since it could be prone to errors.
Hopefully Lightburn support can help with this.
Thanks again.
