My CO2 Lasersource need few seconds after switching the output on ( interlock )
In Ezcad i can activate a button with the function “Laser On”. I switch it and so i simulate the interlock circle. After few seconds the laser let signals go to the source.
I try to simulate this in LB with the Red Dot always on function, but it work not correctly. Between framing and lasering for a short time the reddot turns off and so the timer from the interlock starts new.
I must laser a box in a seperate layer first with no power and then the next layer will be lasered…
If i had here a switch ( Button ) too, it will be better
You must activate this button in the config IO from EzCad.
The Button is normaly not activated.
If you give Laser Power IO a portnumber ( in my example the enable input port from the laser source ) the button will be shown in the normal EzCad Menü und you can set so the interlock or for a nd:yag you can switch on/off the pumplamp or the pumplaser.
No no… not a dual galvo, a pure co2 Galvo with a lmcv4 card. The source is a synrad firestar with 30 watts. And this source series has a interlock and after clothing this interlockline i can work with this source after few seconds.
I can send the manual with mail, if you want. Attache in this posting dosen´t work
