I am currently in the process of switching over to a new computer. I am currently using lightburn v 1.4.00 as I have run outside of the update window, but it still works great. Question on how to transfer. It is my understanding that I deactivate on my current and use the license key on the new? I’m not sure which version to download. 1.4.00 exe, 32 bit 1.4.00 exe, linux 64 v 1.4.00 7z, or linux 64 1.4.00 run? I use xtool d1 pro 20 and omg 60w fiber. any help would be greatly appreciated.
That would work fine. Note that if you have a standard license that you can install and run on 3 computers simultaneously. That could be an option if you intend to keep the original computer around.
Sounds like you want to run this on Linux. If that’s the case then either the 7z or .run versions is what you want. The .exe files are for Windows only. Whether the 7z or .run version is more about what’s relevant for your case. The .run I believe will create app shortcuts on Gnome based desktops. The 7z is more DIY.
