Dear support,
I have seen these instructions for enabling system locked licences (Licensing Setup - Configuring different license options) however, there is no mention of how to do so on a Linux install. Is this supported or will I have to consider alternatives?
Thanks, Tom
Not certain if it would work but have you tried applying the approach listed for MacOS?
sudo ./LightBurn -l (license key)
Where ā-Iā is a lower case L and no actual parentheses around the license key?
That does appear to work correctly! Might be worth amending the FAQ post to note that the same approach should be done for Linux.
