After updating Lightburn software, my T1 and T2 stopped working to frame, how can I fix this??
Are they set to show on the layers?
It looks like you have all layers set to NO output.
A tool layer, by its nature- does NOT output.
So to frame the job, something must be selected to output. Even if you use the T1 or T2 to set bounds of the area to output,
I use frame from a Tool layer daily for just this purpose- to align what I want to cut oriented to a tool layer.
The problem I’m having, is for example, if I have T1 on for the alinement of the material and layer 01 for the image I want to engrave, it will only frame the 01 layer and not the T1 layer. Prior to updating to 1.4, it would frame the T1 layer, then when I started the burn it would burn the 01 layer. This is way I’m confused.
If you select both T1 and 01 does it frame the T1 layer?
Is the 01 image area inside of the T1 area?
If you put a circle inside a square, set the circle to 01 and the square to T1, does it frame the square?
Also- if you run a “Preview” of the setup, do you see only the 01 layer?
If you select both T1 and 01 does it frame the T1 layer? If I select box frame then no only the 01, but if I select the circle frame then it will frame T1
Is the 01 image area inside of the T1 area? Yes
If you put a circle inside a square, set the circle to 01 and the square to T1, does it frame the square? No, only the 01 layer
Also- if you run a “Preview” of the setup, do you see only the 01 layer? Yes
I suggest you send an email to Lightburn support. A video capture of what you are seeing would help. Under “Help” in Lightburn there is an item “Generate Support Data,” do that first and include it with an email to Lightburn. [support@lightburnsoftware.com]
