Tab default and placement
I’ve searched and didn’t find an answer in the archives.
Is there a way to change the default on tabs? Mine seems to be set to .197 (inch) but I find that a bit too large for most of my projects. I would like to change the default to something smaller.
Also, I believe I know the answer to this next questions but is there a way to automatically set the tabs to find a corner in the project? I have found when I manually adjust the tabs to the corners the residual effect is less noticable than if it was on the side. I doubt there is because if the shape has no corners (like a circle) it wouldn’t work. I believe manually placing the tabs is still my best option.
You should be able to adjust in cuts/layers and then make default.
Thank you, I’ll try again. I had already tried that with current files and didn’t notice a difference. I’ll bet I should have opened a new file to see if it worked rather than an existing file.
That worked. When I selected Make Default, it worked. Logically, I had to close out of Lightburn all together and when I opened a new document, the tabs were set to default at my desired number.
