Hi, I’ve been using Lightburn for a long time now and I have had this issue since it was added. When I add tabs to a design they work perfectly, i then save the design for later use. Once I reopen the design and cut the tabs don’t work, I check them and they are all still there, they only seem to work if I manually move one of the tabs. Its like it doesn’t recognise them until I edit one of them and then it recognises all of them and they work perfectly again. I have been meaning to report this several times but never found the time, so i thought it was about time I did as its a pain and I always forget to manually move a tab before sending the job to cut and everything falls out instead of staying in place.
I am now on version 1.4.01 and its still happening.
Thanks
Thank you for taking the time to report this.
I’ll add a note (with info from your profile) that this is happening in Win 11 and a Ruida Controller. I’ll send it to the Dev team. I will test with a Square on my win 10 to see if i can replicate the unanticipated behavior.
Hi John
That’s really appreciated, thank you. I hope you can replicate and fix as it’s the only thing I have negative to say about Lightburn, I love it.
Regards
Lee
It’s my pleasure. One final thing for my report. Are you running LightBurn 1.4.01?
Hi John
Sorry I missed you response, yes I am currently using 1.4.01 but this has been the same since it was introduced.
Thanks
Lee
HI, I was just wondering if you had been able to reproduce this issue as its a real pain not being able to rely on the tabs?
Thanks
Lee
