Hi
I’m using LB 1.2.00. When I set up a material and enable the Tabs option for that material, everything seems normal once I assign that to a layer…I can see auto generated Tabs. I save everything (incl library) close LB, then re-open and the Tabs have all gone and library entry no longer has Tabs enabled.
I also tested with a minimal config/new library with just one entry and same, effect, Tabs come back disabled when I reopen LB for that material
Bug? Or me ?
