Hello
I would like to make ink stamps it is absolutely necessary that the profile is sloping if yes how you do
thank you
Hello
Thanks for your help
you have to be in scan mode to do this with a bmp or you have to use vectors if you have an example to provide me to better understand
thanks again
You can do this in either Fill mode or with an image using Threshold mode.
I’ve also just realized that the Ramp feature for images will only work if you have “Fill Shapes Individually” enabled - it doesn’t work with multi-scanned images.
merci pour aide
thanks for help
