Taper Correction Not Working
Anyone have any fixes for using the Taper Correction feature?
Every time I use it, plug in my values and go back to the work screen my image disappears.
Win10
LB 1.7.07
Just tried it for both image and vectors. Nothing disappeared here.
Maybe a MAC user can test?
Thank you for drawing our attention. I was able to reproduce this behavior, in both the 1.7.07 released and the RC3 for our upcoming 2.0, when the original image is rotated 90Âş or 180Âş. I have generated to report for further investigation. :slight_smile:
Awesome while you’re at it why don’t you rename all the stuff to actually make sense :wink:
“All” is a lot. Are you willing to be a bit more specific?
Absolutely.
The naming of the systems seems very arbitrary and a bit confusing. Top length bottom. Then asks top is (left, right). This seems very arbitrary to me. I am sure it is not, but the cup picture as reference disnt sync with my mental visual. For my situation, my “top” corresponded to length, which was not an option. I selected right, but it ended up being wrong. I was correcting for a taper along the X axis, so it seemed it should have been straightforward, but was not.
Maybe just a few more pics, or an axial reference would help. I ended up just trial and erroring it.
Hope this helps?
edit had a chance to rest and am clarifying a few things so it may be more helpful to what is confusing to us laymen / end user.
The main issue I am having is top / length / bottom in relation to the "Object Top is: " dropdown…in relation to what? I feel that we all use our own frame of reference when looking at an object (for instance in orthographic projection the front/top/side usually has to do with the end orientation of an object, but in actuality front/top/side is arbitrary outside of placement of the 3D object within a space, and has more to do with aligning the axis to have the correct, desired outcome on which side is facing where.
I believe that there is a bit of a disconnect between what I am assigning in my head as top/length/bottom, and what is actually referenced on the machine side. I lack the input to align my image with the programs axis to sync what I need to happen.
