I am very new to this so I am looking for help.
I don’t know what is happening. It was working just fine and then the Target Buffer Size Not Found appeared and it went to homing.
Waiting for connection…
ok
[AUTHOR: RenShen]
[MODEL: Ortur Laser Master 2]
[OLF: 137]
[DATE:01:15:16 - Apr 20 2020]
[VER:1.1f.20170801:]
[OPT:VZD,35,254]
Target buffer size found
ok
Homing
ok
Starting stream
[MSG:Pgm End]
Stream completed in 0:01
Starting stream
[MSG:Pgm End]
Stream completed in 0:02
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Stream completed in 0:00
Starting stream
[MSG:Pgm End]
Starting stream
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
Layer C00
Job halted
Stream completed in 0:07
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
Ortur Laser Master 2 Ready!
OLF 137.
Grbl 1.1f [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
ok
[AUTHOR: RenShen]
[OLF: 137]
[OPT:VZD,35,254]
ok
Homing
ok
$0=20
$1=50
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.050
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=7
$24=600.000
$25=3000.000
$26=100
$27=2.000
$30=1000
$31=0
$32=1
$33=250.000
$100=80.000
$101=80.000
$102=80.000
$110=9000.000
$111=9000.000
$112=9000.000
$120=2200.000
$121=1800.000
$122=2500.000
$130=400.000
$131=430.000
$132=1.000
ok
Starting stream
[MSG:Pgm End]
Starting stream
Layer C00
Job halted
Stream completed in 3:58
ok
ok
ok
ok
ok
ok
ok
ok
ALARM:3
ok
OLF 137.
ok
Starting stream
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
Layer C00
Job halted
Stream completed in 0:09
ok
ALARM:3
OLF 137.
ok
Starting stream
Layer C00
Job halted
Stream completed in 0:13
ok
ALARM:3
ok
OLF 137.
ok
Starting stream
Layer C00
Job halted
Stream completed in 5:31
ALARM:3
ok
OLF 137.
ok
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
Layer C00
Job halted
Stream completed in 0:08
ok
ok
ok
ok
ok
ok
ALARM:3
ok
OLF 137.
ok
Starting stream
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
[MSG:Pgm End]
Stream completed in 1:55
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
Layer C00
Job halted
Stream completed in 0:16
ok
ALARM:3
ok
OLF 137.
ok
Starting stream
Layer C00
[MSG:Pgm End]
Stream completed in 4:30
Starting stream
[MSG:Pgm End]
Starting stream
Layer C00
Job halted
Stream completed in 0:14
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ALARM:3
OLF 137.
ok
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
Layer C00
[MSG:Pgm End]
Stream completed in 6:09
Starting stream
[MSG:Pgm End]
Stream completed in 0:03
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
Layer C00
[MSG:Restoring spindle]
Job halted
Stream completed in 4:58
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ALARM:3
OLF 137.
ok
Starting stream
Layer C00
Connection lost
Stream completed in 14:40
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
[AUTHOR: RenShen]
[OLF: 137]
[OPT:VZD,35,254]
ok
Homing
ok
