Terrible luck with chillers
The title mostly says it all… Chillers keep crapping out. I’ve gone through a lot of the older forums here, and see some report similar problems.
TL;DR: Looking for a non-CW5xxx cooler
More background:
I started with a CW-5000, and after about 2-3 weeks, it stopped cooling. Got a replacement, after another month, same problem.
Went with a different branded CW-5000 (Vevor), same issue.
Got one from LO, it lasted about 6 months, and then failed, they sent a replacement that lasted 2 weeks before the pump started leaking and the compressor started arcing and tripped the breaker.
I am not interested in a DIY setup with external pumps, buckets, etc… preferably a closed loop system like the above. Anyone have any brand that is different and reliable?
Thanks in advance…
What’s the weather like where you’re running it?
My first one arrived DOA, but the replacement works fine… I live in the SW desert area of Arizona, so it gets hot.
Southeast US… So summertime sees mid-90s (F), higher side of the humidity spectrum.
I only run it when I use the equipment, so it’s not 24x7 (likely 2x / week, 4-5 hrs at a time)
I have the Southern “garage fridge” that has been going strong for 15 years, so even something that is 1/4 as reliable would be awesome
Recommendations welcome :stuck_out_tongue_winking_eye:
I don’t really have any suggestions.
I have a distant friend who’s in the AC business. He deals with commercial AC and I ended up giving it to him. He fixed it as it’s gases leaked out, and also the leak. There were no valves to attach to equipment, so he fabricated a couple and got it running.
He sold it for me… don’t know what he got for it, but he gave me the $80 bucks I was out :tada:
My only suggestion is to a higher quality one… I really don’t know what to suggest.
Hang in there and lets wait for some other suggestions.
Yeah… I think that’s the thing. This seems to be the primary (only?) game in town… unless I want a $10k glycol chiller :joy:
Thanks for the response, glad I’m not alone. Here’s to hope
Thanks for sharing… glad to know that there may be some possibilities for DIY success here. Really appreciate the links.
Thanks!
