Test Material Engraving
Trying to run material tests, have cutting done. How do I change to engraving for different materials to run my test material files?
The only difference between engrave and cut is the power/speed settings. A deep enough engrave will be a cut…
Use the fill option for the layer in the materials test to get more of an engraving operations along with changes in speed and power…
Make sense?
Thanks, yes that makes a lot of sense.
