Text in a dxf getting off centered after importing
The text is getting off centered after importing a dxf. On AutoCAD it’s aligned perfectly centered but when I import it as a dxf on LightBurn, it’s not the same. It’s not off by a lot but for my task it needs to be as perfectly centered as possible. So I measured the offset and applied it on AutoCAD so when imported it’s centered in LightBurn but it’s a random offset for different drawings. I have provided the screenshots below as an example, if you see on LightBurn, the text and blue rectangle don’t have the same XPos which it’s off centered but on AutoCAD it’s centered.
