Some text is flipped in image when I reload a saved image. This just started after version update and license was purchased, worked fine in trial.
Did you change where the origin is located? That would do this.
Had same issue and modified origin and was finally engraving the correct side for text.
And when I change the origin AFTER loading somthing in workbench then it flips averything.
This is intentional, and as designed. If you move the origin, you’re changing the position of ‘zero’ and the direction of positive X or Y, depending on which point you move:
If the origin is front-left, then +X goes to the right, and +Y goes toward the rear. If the origin is rear-right, then +X is to the left, and +Y goes toward the front.
In the example above, the word ‘Test’ is in the same orientation relative to the two origin points.
