Text on Spiral - Trying to reverse direction
Since LB can not create a spiral easily, I made one in Inkscape and then placed it in LB.
I then applied text to path, which works, but its written from the center out.
I need it to be written from the outside.
But nothing I do will get it to do that.
I figured the answer to this would be the Set Shape Start Point tool.
Which if I use that, it will place the arrow at the other end, but it has no effect.
In Inkscape try reversing the direction of the spiral path before importing.
Select spiral, Path->Reverse. Make sure the shape is a path first and not an object.
Thank you ! Worked perfectly, I should have thought about that, but not messed with Inkscape enough yet.
