I’m new to Lightburn with EZCAD galvo laser. When I enter text horizontal what is engraved is vertical and backward. I’ve tried doing a new install. I’ve searched for an answer but I can’t find it. EZCAD2 doesn’t have this issue. I would appreciate any help I could get on this issue.
I have just got a galvo and am going on a steep learning curve myself, I believe you may have the wrong ‘Galvo’ set to the x axis.
Go into device settings and change it if after that if the text is backwards enable the ‘reverse direction’
Thanks very much for your response. I saw the reserve direction tab was enabled so I changed it. I hope that will fix it. I will try tomorrow and report my findings.
The other issue and I’m not sure if they are related is that the red preview marking doesn’t match where it is actually marking. I’ve included a photo showing this issue. I keep adjusting it in the settings but when I open the program again the problem returns even though the corrections I entered are still in the settings. In this photo you can see the white burned marking is lower than the red preview marking. Again I would appreciate any assistance.
Changing to the other Galvo (see screenshot in my previous post) should solve your orientation issue.
You do however seem to have other setting issues.
Did you import the Ezcad settings when you created this device in Lightburn ? If not I recommend that you do.
The following video should help
