when I want to engrave a text or photo, it lasers it in mirror.
i use lightburn and sometimes lasergrbl which i got with my laser (i have the totem two trees 5.5w laser)
how can I make sure that it engraves it properly?
That’s masking the problem, not fixing it.
I suspect you have your origins mixed up.
The lightburn machine origin has to match the origin for your machine.
This is mine - it won’t necessarily be the same for your machine.
When your machine homes, where does it end up? That has to be the setting you use in your machine settings in lightburn.
The two-trees laser likely doesn’t home, so you’d need to power it up with the laser head in the front-left position, and set the origin that Bo shows to match it. That should work.
my machine does not have home.
the origin is now at the bottom left
Had same problem. Was due to laser mounted on wrong side of the x-bar. When mounted on other side, engraving got correct
Hi @Kimdl - did you fix the rpoblem? is it as @asbnord suggested with the laser being mounted on the wrong side of the xbar? Im thinking of purchasing the Twotrees Totem S (and also considering the ORTUR 2) but im concerned if it is not compatible with LightBurn.
Yes the problem is fixed
Thanks Kim. Would you recommend Totem S with Lightburn?
I’m about to buy this totem s laser like @vincent , and I will do the same question: Would you rekommend the combination?
Thanks in advance!
Yes! It works very well for me
