after putting text to path
when i try to move the object the text doesn’t move the same and yes i did group it together how do I fix this or whats causing it
It’s because of the way grouping affects it - you’re moving the curve it’s attached to and the text, because both are in the group, so you’re effectively moving it twice. The simple fix for now is to convert the text to a path, and then it won’t happen any more.
That works. Thanks for the help
It’s something I plan to fix. I should look at getting this into the next release… It’s annoying.
Ok, this is fixed. That was much more of a pain in the rump than I was expecting, but it seems ok - I’ll put it through test.
