@berainlb Here you are, with 200 speed ![]()
Looks like nothing wrong in my opinion.
That’s interesting. Try building a spiral made of 90 degree turns. Run it twice, once inside out, then once outside in.
Hi guys,
after houndreds messages with the supplier and their “engineers” during last week, I haven’t had a solution yet. They said something like “Oh, ok, decrease speed to 30 mm and the problem will be fixed” ![]()
Obiouvsly, this is not THE solution, but only a fast way to say “Problem fixed”: having bought this machine to work (not for hobby) i need it can cut faster than this.
This is what i have checked:
To understand if the problem comes by lens/mirrors i have also swapped a pen with the autofocus sensor and made a test draw with 0% power.
As you can see in the picture below (START in upper right corner, END in lower right corner), wobble lines persist in every circle and also when the head moves from a circle to another one.
I really think it could be a problem caused by a setting value combination of speed, acceleration and deceleration, or a issue on step motor/controller.
I’m really sad to can’t find a solution, and if you have any ideas or something to try it will be very appreciated.
