The cutting along the x-axis is 2 mm smaller than specified in the program.
Please help me with the solution of the problem, I am a beginner in laser cutting, when I cut along the x-axis, the size for some reason turns out to be 2 mm smaller than I set in the program, I tried different sizes of squares 5x5, 4x4, 3x3cm, and always along the x-axis the model turns out to be 2 mm smaller, and along the y-axis everything is ok, the lasermatic mk2 laser was installed as indicated in the instructions, I also tried cutting from Windows and from a MacBook, also the problem is 2 mm is missing
Might be worth giving the ‘calibrate axis’ a go, if you haven’t already
