So I have had this problem for a while, I am trying to make a design which has two layers, fill and line. The problem is that the inner layer is not centered on the outer one. I also noticed another problem when I tested only the lining, the box that sits in the middle always goes to the left and it’s not centered properly (I did manage to fix this by reducing the width by 1mm). The machine I am using is AtomStack x20 Pro with Rotary Roller. I watched all the videos regarding the rotary setup, I calibrated the Roller Diameter as well as mm per rotation, ran a couple of tests and everything works perfectly until it was time for engraving. I also tried messing a little bit with the machine settings, I lowered the acceleration and speed dramatically but I and up with the same result.
