The laser module does not fire while engraving and cutting. Emergency help.
What laser, OP system and version of software. please.
Algolaser alfa 22w
lıght burn 1.7.03
$0=5.0
$1=100
$2=0
$3=0
$4=7
$5=3
$7=0
$10=2047
$11=0.050
$12=0.002
$13=0
$14=0
$15=3
$16=0
$17=4
$18=0
$20=1
$21=1
$22=1
$23=7
$24=1000.0
$25=5000.0
$26=150
$27=3.000
$28=0.100
$29=0.0
$30=1000.000
$31=0.000
$32=1
$33=2000.0
$34=0.0
$35=0.0
$36=100.0
$37=0
$39=1
$40=1
$43=1
$44=3
$45=0
$46=0
$62=0
$63=3
$64=0
$70=27
$73=1
$74=My_SSID
$75=***********
$76=ALA1_AP_9670
$77=12345678
$100=100.000
$101=100.000
$102=100.000
$110=30060.000
$111=30060.000
$112=600.000
$120=2000.000
$121=1800.000
$122=200.000
$130=400.000
$131=400.000
$132=100.000
$160=0.000
$161=0.000
$162=0.000
$180=30060.000
$181=21042.000
$182=600.000
$270=115200
$271=115200
$272=115200
$300=ALA1_STA_9670
$301=1
$302=192.168.5.1
$303=192.168.5.1
$304=255.255.255.0
$305=23
$307=81
$308=21
$310=ALPHA_AP_9670
$312=192.168.5.1
$313=192.168.5.1
$314=255.255.255.0
$332=255
$341=0
$342=30.0
$343=30.0
$344=180.0
$345=200.0
$384=0
$600=0
$601=5
$602=0
$603=5.0
$604=6.0
$605=1
$606=1
$607=0
$608=1
$609=10.000
$610=0
$611=0
$612=1
$613=4294967295
$614=0
$616=0
$617=0
$618=0
$622=111
ok
When framing or when you hit the fire button the laser works or not?
It also doesn’t fire when I’m framing and clicking the laser button.
I’ll check the cable connections.
If still not works. I hope someone else can assist you. Maybe @gilaraujo can guide you.
ok. thanks
On the laser head
Do you get both LEDS, and fan moving?
Sorry for can’t help you more.
The laser module is moving. Fan is working. Air, flame and lens lights are on. Only the laser light does not turn on.
Can you take a picture of the LEDs, or even a small video if you can post it on youtube and share link
You might be missing the PWM signal at the laser head.
This is a support@algolaser.com issue really as you will have to do hardware inspection
Ok. thanks
