The laser start opposite of where it should and Framing is so very slow now
After I home the laser in the lower left with the diagram read to start, I hit the frame button, and the machine moves at an extremely slow pace. This is a totally new problem. After the framing completes, I hit the start button, and the machine will travel to where I think it should start. However, thinking it will move from the lower portion where it has started, and move to the upper area, engraving as it moves. The laser instead moves in the opposite direction and runs off from the lower end of the wood. It starts engraving on what should be the second piece to be lasered. In essence, it seems to be working opposite of what it should. I cannot remember changing any settings. I have not used it for 2 weeks. Maybe I have changed something. I have used it in all three settings: User Origin, Actual Coordinates, and the current position. it. It does the same thing in all startups. To finish a aproduct, to sell, I do one part at a time with all others removed from the diagram and then add the next part. Very tough and slow going.
Does the Origin in the Device Settings match the position of your Home switches?
These are 3 completely different operating modes. There should have been a variety in the results. You should be using Absolute Coords only, if you expect to be moving around the work area.
