Zdravím, prosím o reakci, co mám nastavit, aby laser vyřezal celý projekt? Po nějaké době laser zhasne, i když se stále pohybuje, ale neřeže. Mám Algolaser Delta a notebook Dell s Windows 10. Děkuji za rady. Iva
Are the physical wires to your diode securely seated in their connectors? Is your power supply connected securely? If your power supply has an indicator light on it, does it also shut off while lasering? That would be the first thing to check.
How old is the machine? Is it new or used?
