The lightburn macro link in Corel does not seem to work with the new Lightburn 1.0.06. Is there a new macro installation procedure??
Yes, it did work in a previous version. You don’t get the same quality if you export from Corel to a JPG and then import into Lightburn and trace the image.
The big issue was I had to modify my install of Corel Draw 2021 to manually enable the Macros feature. After that, I was able install and the macro is working perfectly. Here’s a more visual guide that helps as well. PDF
To manually install the macro features
1 On the Windows Control Panel, click Uninstall a program.
2 Double-click CorelDRAW Graphics Suite 2021 on the Uninstall or change a program page.
3 Enable the Modify option in the wizard that appears, and follow the instructions.
4 On the Features page of the installation wizard, enable the following check boxes in the Utilities list box:
• Visual Basic for Applications
• Visual Studio Tools for Applications
The macro features for VBA and VSTA are installed with the software by default.
