I am using LightBurn 1.5.03, built Fri 2024-03-08 @ 14:54 and IKIER K1 Pro machine.
I tried setting up the camera and made a 400mm * 400mm square with diagonal lines. When the machine moves all the way to the right, it stops. it shows the message " Starting stream
Layer C00
ALARM:1
Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended.
On or near line 0:
Stream completed in 0:06
ok
Grbl 1.1h [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
error:1
G-code words consist of a letter and a value. Letter was not found.
ALARM:1
ok"
My engraver areas supposed to be 410 * 410, unfortunately the machine hults when it reaches the far right.
Your support will be highly appreciated.
