Hello,
this is my first topic and this is my question:
I started with lightburn and the laser Sculpfun S9 - the function was normal and pretty.
Now I changed at the expanded version 42cm x 92cm.
I changed the parameters and started again.
The have no perfomance - the movement is very slowly.
What is the mistake - what can I do?
Thanks for your answer.
thanks for your answers.
This is the newest state:
I found that only the Y-axis is very slowly. If I move the Y-axis manuel the speed is correct.
Than I changed the X and Y - cable on the mother-board the result was, the X-axis was correct the Y-axis was slowly.
My questions:
Can I repair the board DLC V1.1 ?
Can I get a board from Sculpfun (warranty)?
Is the newest version DLC V1.2 the better alternative?
Hi,
I only changed the parameter height and width for the new expanded dimensions.
After them I am able to change the X- and Y- values. But if I change the Y-value alone the machine makes fast movements. Alone the X-axis and combined with Y-axis the machine makes very slowly movements.
I hope this answers your questions?
Michael
Hi,
thanks for your help - I found the solution.
After I contact Sulpfun I got the tip: install the firmware new.
After I do this, the machine was running ok at all axis
Michael
