Today I encountered an interesting situation. I needed to engrave in grayscale the following drawing:
To select the right mode, I took a small piece of this image to save time. Here is an example of this image (size in mm 5x4):
I started engraving and got an incomprehensible image at the output. After that, I went to the preview and saw exactly the same result as on metal:
If I take a larger drawing size, the situation improves:
If I increase the size of the pattern, the problem goes away. with the exception of one: the interval between the gradation:
In the picture above, you can see white stripes, they will be visible later during engraving.
Tell me how to solve these problems. Thanks in advance.
