The problem of many points in engraving
At the time of engraving the machine makes points on the product
If it shows on the preview, it will show on the laser.
Is that graphic an image or a vector? Make it a vector and delete all the garbage. Use the TRACE command to make a vector object, ungroup the vector objects, select and delete to spurious spots.
Also may want to turn down the speed a little bit. The excessive red outline shows the laser head is travelling very far without any engraving happening. Useless movement.
