Any flat or Matt paint should work as long as it not water based
Try Lowe’s I recently bought some.
https://www.lowes.com/search?searchTerm=4+x+4+ceramic+tile
Cheers
Sasquatch
Isn’t that tile painted black not white?
Nope. Painted white. White tile, white paint. Magic, ain’t it?
Doesn’t that waste a lot of engraving time?
That quality can only come from a diode laser that is able to fire @0.75 watts
So time is all you got . No microwave speed for this tile artwork. Kind of like instant chocolate pudding vs. real chocolate pudding made from scratch .
One takes longer but boy can you taste the difference. In @Bulldog artwork you can see the difference.
Cheers
Sasquatch
I developed a process to paint ceramic with Flat White paint,then laser…the paint reactes with tile and burns the tile black…https://www.youtube.com/watch?v=sk2A9F8Vunw&feature=emb_logo&fbclid=IwAR0D5uOC4zxyKuKFlvL5PMafNOJe7OlJUDzrkD3t6HICy10809NxvwOMgDk
Its a diode,very slow…1-2 hour per tile ,but it is totally scratch resistant
I have been looking at doing something like this. What type of paint are you using?
Read this post
Cheers
Sasquatch
I just did my first test burns. All I can say is WOW! It works surprisingly well. Now to dial in my speed and power settings. Great fun!
@Blake most of my prep now I do with LightBurn under shape properties …I use paintShop to first resize
Here is business opportunity for your art during this quarantine. Came across this stuff which is inferior to yours
Cheers
Sasquatch
Thanks…Plus all the copy right laws…My laser has been mothballed for a while while I deal with some issues at hand…take care…thanks for all your kind words…
God Bless you @Bulldog. Be well and stay safe.
Sasquatch
I just picked up a box of 100 4.25X4.25 white tiles from Home Depot here. It was just under $16 for the box.
I also picked up some flat black paint and tried that. It just burns the paint away leaving the white tile where you lasered. That opens up another dimension of playing around.
Those look great! What do you use for your clear coat? I tried using a spray lacquer and that was a fail. It reacted with black paint. Do you clean these with anything before you clear coat? I used a little water and that didn’t seem to do anything. Maybe there isn’t anything more than a quick wipe needed.
@Arthur…wipe down gently with Methyl Hydrate …micro fibre …then use water base clear coat
