what is the basic settings in the LB console $$
$$ is a GRBL command that will cause an attached GRBL-based motion controller (firmware at the laser machine) to return a bunch of useful $-Code settings, most of which you can read about here:
https://github.com/gnea/grbl/blob/master/doc/csv/setting_codes_en_US.csv
Your settings are likely to be quite different to everybody else’s, as the factory will modify these settings for each build.
If you paste your settings here, we can check they are roughly ok, or somebody else might have the same machine.
Thx Nicholas
for taking time to help a newbie
ok
[G54:12.400,-3.850,-8.166]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
$0=10
$1=250
$2=0
$3=1
$4=0
$5=0
$6=0
$10=115
$11=0.020
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=3
$24=25.000
$25=250.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=40.000
$101=40.000
$102=188.976
$110=8000.000
$111=8000.000
$112=500.000
$120=500.000
$121=500.000
$122=50.000
$130=750.000
$131=750.000
$132=100.000
ok
We can’t judge these settings since they are individual for your machine. Which machine do you have? Do you have any issue?
Since you don’t seem to have deeper knowledge (no offense), you should not change any of them if your machine is running fine. You can do any tuning later if you got used to your machine very well.
I have X-Carve
and J-Tech laser 44W
So, these are the settings of an X Carve machine? It has a laser module mounted? Check out what settings X Carve recommends. The settings need to match your machine, it’s simple as that.
