In lightburn, it is 5 cm, but when it is actually stamped, it will be 4.7 cm.
Since I haven’t touched any settings, will it be possible to engrave normally with some settings?
Please help everyone. … …
First check to make sure that your belts and wheels are not on too tight. If the engravings look clear and not distorted then you’re probably okay.
If there’s no mechanical issue then you may need to calibrate your axes.
Check here for how to do that.
