Hello,
is there a way in Lightburn to display the web widths when cutting plywood or other materials or perhaps even to issue a warning if the web width falls below a certain width (e.g. 0.5mm)?
I lasered or cut a pendant for the Christmas tree for a friend.
The motif has very thin contours.
Many of the contours of the motif are so thin that some of them have already burned away.
A function like this would actually be very helpful for this use.
Ihave now used offset to enlarge the thin webs of the contours by approx 0.3-0.5mm.
Let’s see what the results are then.
I can upload the file when I get the chance.
The problem is not about bridges or connections.
But about cutting paths that are sometimes too close to each other (due to the image, shape and contour).
I derived the paths from an image.
