Hello,
I`ve samo problems with rotary axis on thunderlaser ODIN.
Setup: thunderlaser ODIN 32 + two different rotary axis and latest version of lightburn (1.7.06).
I can engrave with rotary axis and engravings are good, but setup is kinda bugged.
I can turn my rotary axis using controls in lightburn move window but when I`m trying to setup rotary job using lightburn rotary setup window test button it moves wrong axis.
Frame buttons moves wrong axis.
Seems like 1 and 2 are correlated but is this a bug in LB or I missed some config checkbox?
LB can move rotary axis without problems and it cannot make it to move point 1 to 2 to 3 to 4?
Start button doesnt work, but when I send job using send button it will be evgraved just fine except…
Engraved job is missing first ~0,5mm of the project, to counter this I have to add for example 0,05mm circle 0,5mm before the project itself.
I have added pause before engarving start so after starting job from ruida panel it moves rotary axis, pause for 2 sec, and start engraving but this changed notning.
I`ve read that thunderlaser uses customized firmware on ruida, and it causes problem numer 3.
What about 4? It happens on both of my rotaries, also the same rotaries on different laser dont gives this effect so they are fine.
