A more simple explanation is that the base pwm frequency is actually referred to as the period. That’s because a pwm signal is frequency independent. It’s called the period, which is 1/base frequency. A 1kh base frequency is actually 1/1000, which is a period of 1ms. A 20khz pwm frequency sent to a co2 would be 1/20000 or 50 microseconds (µs) period.
This comes into play as most digital equipment work with either off/on signals. Whereas pwm can be used in many analog definitions. Might not think of it but the sun going up and then down is a form of PWM with is period of 12hrs, notice the units are in time, not frequency. Also the pwm isn’t a square wave… It can be any type of waveform, including analog signals that can be pwm modulated.
The world and most of these electronics are cheap to manufacture using only the brains of the controller, does a digital pwm almost intuitively.
An led laser and an RF laser are digital devices and follow the pwm on/off cycle. However a tube is an analog device and doesn’t respond fast enough to be directly digitally controlled. It gets converted to an analog signal in the lps.
You need to check your diode, they are fast, but many manufacturers state explicitly state what the bottom period (higher frequency) of the pwm that can be used.
On a digital device such as an RF laser, the period change can have a noticeable effect on the results on the material.
Few of us have the equipment to really use a change in the period.
As @ednisley was advising, a LED or RF laser will follow the pwm for power. 50% power would turn these devices on for 1/2 the period and off the other. Most led lasers exist in such low power levels, I don’t think you will observe a difference in use.
However a co2 is an analog device with a relatively slow response time, so it can run all day at 50% power, continuously the whole time.
Hope this helps clarify how the pwm interfaces. Might want to carouse the wiki on it.
Hope this makes sense?
