Today I did my first test using white water-based spray paint…
700 mm/min, 85% power, 30W laser (5W optical output)
In this second image the same settings except for the speed of 1000 mm/min
New test, now done with ordinary white spray paint (solvent based)…
the regular ink gave a slightly stronger black, but the water-based ink seemed to give me a little more definition… I’m still going to do some more tests…
one detail is that the ceramic is for flooring (32cm x 32cm) cut into 10cm fillets (to make a baseboard)… it is a little rough, I can’t find small tiles (10x10, 15x15) for the wall, which are usually smoother , should make some difference in engraving.
Sorry for the google translation.
