The Controller is not going below 200 speed and on lightburn it worked in past but recently trying to cut at lower speed and only does at 200mm/s. power works great but not the speed! pictures attached to help out, thanks
117169603_10164064706145192_1015080024782160831_n|280x500
also followed manual on page 35 https://www.madeinpredappio.it/TL-3120%20Motion%20Control%20User%20Manual.pdf
Are you saying that when you run a job it’s not moving slower than 200mm/sec, or that when you send a job to the controller, the displayed value next to ‘Speed’ isn’t changing? The speed value you see there is your jog speed, and doesn’t have anything to do with the file being run.
