I already have LB 1.6.03 installed with two machines/device already set up and would like to NOT have to reinstall LB to install the EZCad driver via the tickbox during my first installation. (Now adding a new fiber/galvo laser). Does the following program/method have the driver embedded?
From a help page…
Alternately, the installer for the driver is in the LightBurn files at "C:\Program Files\LightBurn\EzCad2Driver" and can be run again via the “dpinst-x64.exe” file directly.
So, as I take it, running the “dpinst-x64.exe” program will contain/install the EZCad driver when it is run?? IF this method works it will save a lot of time in not having to re-configuring my already configured devices. Thanks ahead of time for any help you 'all may provide…
P.S. I do not have my new fiber laser YET, SB delivered next Tuesday - Right now getting my ducks in a row ![]()
GOT IT…
LB help desk said that a new install would be best and my continued vigilance in finding a solution paid off. I will FIRST export a “Bundle” containing only the specific settings for my “Blue” and “Red” laser devices. Then, after a new re-installation of LB, I’ll perform a “Bundle” import of the two devices I needed to save. AND, I will be certain to hit the “install EZCad driver” this next install… Maybe this method will also benefit some other user with the same situation…
