Too many cuts in lightburn
Hello! Is it possible to skip cuts in lightburn? For example I set 12 cuts, but after 8 cuts, the wood is properly cut. How can I skip cuts so the machine continues to cut the next line?
Yes, if you open the preview window you can slide the preview time slider to where you want it to start then click the ‘Start Here’ button.
Here’s a link to the online documentation.
The correct fix is to set the count to the proper value…
