Tool path setup
Is it possible to have the laser follow the design much like a CNC machine would? For instance. For a simple circle, could the path just follow the outline of the circle or does it have to go left and right(or up and down) to make the design? Forgive my ignorance!
in line mode, a laser behaves like a cnc milling machine but without a spindle up and down, (at most machines)
Ah, so there is a way! Thanks. It still shades pretty well? I think this would save a pile of time
Oh I see it now, So for text it wouldnt make the outline of the letters(with line mode) then fill in just the letters without going across the entire text space. Is there a way for it to peform like a cnc would for a pocket for vcarve(without the z axis movement?)
FLOOD FILL! That’ll do it.
I actually think there is someone here in the forum who runs their cnc router with LightBurn and a diode laser mounted.
Don’t use flood fill unless it’s for something very simple. The paths generated go back and forth a lot, and any backlash in the machine will show as gaps in the result.
The newer “Offset Fill” is likely what you’re looking for, but again, don’t use it for really complex shapes. It’s really expensive to generate the paths, but it follows the shape and works well for frames.
https://lightburnsoftware.github.io/NewDocs/CutSettings-OffsetFill.html
hmmm, I’m trying an offset of the shape(which is the shape of the province of Manitoba). It does two or three rounds okay, then the machine squeaks a bit and then its off a bit. get the Alarm 3 error:
Waiting for connection…
Grbl 1.1h [’$’ for help] LongMill build Feb 25, 2020
ok
[VER:1.1h.20190830:]
[OPT:V,15,128]
Target buffer size found
ok
Project loaded in 44 milliseconds
<Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:65.765,48.330,-72.725>
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100>
ok
Starting stream
Stream completed in 0:00
ok
<Idle|MPos:0.000,50.800,0.000|FS:0,0>
ok
ok
Starting stream
ok
<Idle|MPos:0.000,30.000,0.000|FS:0,0>
ok
Starting stream
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C03
Job halted
Stream completed in 15:01
ok
ok
ok
ok
ok
ok
ok
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
Starting stream
ok
Starting stream
ok
Starting stream
ok
<Idle|MPos:79.085,48.330,50.800|FS:0,0|WCO:65.765,48.330,-72.725>
ok
<Idle|MPos:79.085,48.330,50.800|FS:0,0|Ov:100,100,100>
ok
Starting stream
ok
<Idle|MPos:79.085,0.000,50.800|FS:0,0>
ok
ok
Starting stream
ok
ok
ok
Starting stream
ok
ok
ok
Starting stream
ok
ok
ok
Starting stream
ok
<Idle|MPos:79.085,0.000,50.800|FS:0,0|WCO:65.765,48.330,-72.725>
ok
<Idle|MPos:79.085,0.000,50.800|FS:0,0|Ov:100,100,100>
ok
Starting stream
ok
<Idle|MPos:28.285,0.000,50.800|FS:0,0>
ok
ok
Starting stream
ok
<Idle|MPos:0.000,0.000,50.800|FS:0,0>
ok
ok
Starting stream
ok
ok
ok
Starting stream
ok
Starting stream
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0>
ok
ok
Starting stream
ok
<Idle|MPos:0.800,0.000,0.000|FS:0,0|WCO:65.765,48.330,-72.725>
ok
<Idle|MPos:0.800,0.000,0.000|FS:0,0|Ov:100,100,100>
ok
Starting stream
ok
<Jog|MPos:0.815,0.000,0.000|FS:689,0>
ok
<Jog|MPos:1.600,0.000,0.000|FS:0,0>
ok
Starting stream
ok
<Jog|MPos:1.735,0.000,0.000|FS:239,0>
ok
<Jog|MPos:2.400,0.000,0.000|FS:0,0>
ok
Starting stream
ok
<Jog|MPos:2.540,0.000,0.000|FS:239,0>
ok
<Jog|MPos:3.200,0.000,0.000|FS:0,0>
ok
Starting stream
ok
<Jog|MPos:3.345,0.000,0.000|FS:239,0>
ok
<Jog|MPos:4.000,0.000,0.000|FS:0,0>
ok
Starting stream
ok
<Idle|MPos:4.800,0.000,0.000|FS:0,0|WCO:65.765,48.330,-72.725>
ok
<Idle|MPos:4.800,0.000,0.000|FS:0,0|Ov:100,100,100>
ok
Starting stream
ok
<Jog|MPos:5.500,0.000,0.000|FS:0,0>
ok
<Jog|MPos:5.600,0.000,0.000|FS:0,0>
ok
Starting stream
ok
<Jog|MPos:5.660,0.000,0.000|FS:239,0>
ok
<Jog|MPos:6.400,0.000,0.000|FS:0,0>
ok
Starting stream
ok
<Jog|MPos:6.455,0.000,0.000|FS:239,0>
ok
<Jog|MPos:7.200,0.000,0.000|FS:0,0>
ok
Starting stream
ok
Starting stream
Layer Cut Pass 1 of 3
Job halted
Stream completed in 0:05
ok
ok
ok
ok
ok
ok
ok
ALARM:3
ok
Starting stream
ok
<Idle|MPos:79.085,48.330,0.000|FS:0,0|WCO:65.765,48.330,-72.725>
ok
<Idle|MPos:79.085,48.330,0.000|FS:0,0|Ov:100,100,100>
ok
Starting stream
ok
<Idle|MPos:38.285,48.330,0.000|FS:0,0>
ok
ok
Starting stream
ok
<Idle|MPos:0.000,48.330,0.000|FS:0,0>
ok
ok
Starting stream
ok
<Idle|MPos:0.000,7.530,0.000|FS:0,0>
ok
Starting stream
Layer Cut Pass 2 of 3
Layer Cut Pass 3 of 3
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C03
Job halted
Stream completed in 15:24
ok
ok
ok
ok
ok
ok
ok
ok
ALARM:3
ok
Starting stream
ok
Starting stream
ALARM:3
ok
Starting stream
ok
Starting stream
Starting stream
Job halted
Stream completed in 0:07
ALARM:3
ok
ok
Starting stream
ok
ok
ok
Starting stream
ok
ok
ok
Starting stream
ok
ok
ok
Starting stream
ok
ok
ok
Starting stream
ok
ok
ok
Starting stream
ok
<Idle|MPos:0.000,48.330,0.000|FS:0,0|WCO:65.765,48.330,-72.725>
ok
<Idle|MPos:0.000,48.330,0.000|FS:0,0|Ov:100,100,100>
ok
Starting stream
ok
<Jog|MPos:0.000,7.530,0.000|FS:0,0>
ok
ok
Starting stream
ok
ok
ok
Starting stream
ok
Starting stream
ok
<Idle|MPos:0.000,0.000,40.800|FS:0,0>
ok
ok
Starting stream
ok
<Idle|MPos:0.000,40.800,40.800|FS:0,0>
ok
ok
Starting stream
ok
<Idle|MPos:0.000,81.600,40.800|FS:0,0|WCO:65.765,48.330,-72.725>
ok
<Idle|MPos:0.000,81.600,40.800|FS:0,0|Ov:100,100,100>
ok
Starting stream
ok
<Idle|MPos:0.000,122.400,40.800|FS:0,0>
ok
ok
Starting stream
ok
<Idle|MPos:0.000,163.200,40.800|FS:0,0>
ok
ok
Starting stream
ok
<Idle|MPos:0.000,204.000,40.800|FS:0,0>
ok
ok
Starting stream
ok
<Idle|MPos:40.800,204.000,40.800|FS:0,0>
ok
ok
Starting stream
ok
<Idle|MPos:81.600,204.000,40.800|FS:0,0|WCO:65.765,48.330,-72.725>
ok
<Idle|MPos:81.600,204.000,40.800|FS:0,0|Ov:100,100,100>
ok
Starting stream
ok
<Idle|MPos:81.600,244.800,40.800|FS:0,0>
ok
ok
Starting stream
ok
<Idle|MPos:122.400,244.800,40.800|FS:0,0>
ok
ok
Starting stream
ok
<Jog|MPos:161.690,244.800,40.800|FS:940,0>
ok
<Jog|MPos:163.200,244.800,40.800|FS:0,0>
ok
Starting stream
ok
ok
ok
<Idle|MPos:204.000,244.800,40.800|FS:0,10|Ov:100,100,100|A:S>
ok
<Idle|MPos:204.000,244.800,40.800|FS:0,10>
ok
Starting stream
ok
ok
ok
ok
ok
ok
<Idle|MPos:244.800,244.800,40.800|FS:0,10|WCO:65.765,48.330,-72.725>
ok
<Idle|MPos:244.800,244.800,40.800|FS:0,10|Ov:100,100,100|A:S>
ok
Starting stream
ok
<Idle|MPos:244.800,285.600,40.800|FS:0,10>
ok
ok
Starting stream
ok
<Idle|MPos:244.800,274.800,40.800|FS:0,10>
ok
ok
Starting stream
ok
<Idle|MPos:244.800,264.000,40.800|FS:0,10>
ok
ok
Starting stream
ok
<Idle|MPos:255.600,264.000,40.800|FS:0,10>
ok
ok
Starting stream
ok
<Idle|MPos:266.400,264.000,40.800|FS:0,10|WCO:65.765,48.330,-72.725>
ok
<Idle|MPos:266.400,264.000,40.800|FS:0,10|Ov:100,100,100|A:S>
ok
Starting stream
ok
<Idle|MPos:266.400,265.270,40.800|FS:0,10>
ok
ok
Starting stream
ok
<Idle|MPos:265.130,265.270,40.800|FS:0,10>
ok
ok
Starting stream
ok
<Idle|MPos:263.860,265.270,40.800|FS:0,10>
ok
ok
Starting stream
ok
Starting stream
ok
error:9
G-code locked out during alarm or jog state.
error:9
error:9
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
<Idle|MPos:262.590,265.270,-0.470|FS:0,0|Ov:100,100,100>
ok
ok
<Idle|MPos:262.590,265.270,-0.470|FS:0,0>
ok
<Idle|MPos:262.590,265.270,-0.470|FS:0,0|WCO:65.765,48.330,-72.725>
ok
Starting stream
ok
Starting stream
ok
Starting stream
ok
<Idle|MPos:328.355,313.600,40.800|FS:0,0>
ok
ok
Starting stream
ok
<Idle|MPos:328.355,272.330,40.800|FS:0,0>
ok
ok
Starting stream
ok
ok
ok
<Idle|MPos:287.085,272.330,40.800|FS:0,10|Ov:100,100,100|A:S>
ok
<Idle|MPos:287.085,272.330,40.800|FS:0,10>
ok
Starting stream
ok
<Idle|MPos:265.815,272.330,40.800|FS:0,10>
ok
ok
Starting stream
ok
<Idle|MPos:265.815,271.060,40.800|FS:0,10>
ok
<Idle|MPos:265.815,271.060,40.800|FS:0,10|WCO:65.765,48.330,-72.725>
ok
Starting stream
ok
<Idle|MPos:265.815,269.790,40.800|FS:0,10>
ok
ok
Starting stream
ok
<Idle|MPos:265.815,268.520,40.800|FS:0,10>
ok
ok
Starting stream
ok
<Idle|MPos:265.815,267.250,40.800|FS:0,10|Ov:100,100,100|A:S>
ok
<Idle|MPos:265.815,267.250,40.800|FS:0,10>
ok
Starting stream
ok
<Idle|MPos:265.815,265.980,40.800|FS:0,10>
ok
ok
Starting stream
ok
ok
ok
ok
Starting stream
ok
<Idle|MPos:264.545,265.980,-0.470|FS:0,0|Ov:100,100,100>
ok
ok
<Idle|MPos:264.545,265.980,-0.470|FS:0,0|WCO:65.765,48.330,-72.725>
ok
Starting stream
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C03
Job halted
Stream completed in 14:44
ok
ok
ok
ok
ok
ok
ok
ALARM:3
ok
Just an update. Tried using the flood fill and it seemed to work!
