i want to use a rotary-unit with my Topwisdom TL-A1. The controller has input for X and Y-Axis, also a combined input for Z/U (multiplexed port). http://topwisdom.com.cn/Product/detail/l/en/id/2.html
Also I´ve got a 4-pin plug-in inside the machine for a rotary-axis.
Can i use both Axis at the same time? At the moment U-Axis is used for the hight of the platform
Inside the electrician-cabinet the cable of the 4-pin-plug is not connected to any driver - where to plug in?
Any specifications the rotary-units need to work with topwisdom + lightburn?
I´m indeed running it since a while with LB and it works very well. No issues with sending data or sth else. Only connecting the rotary-unit seems to be a problem, at least for me
I thought of swapping the U-Axis (Hight of the honeycomb) to the rotary-axis. I have the option to set the hight manually, so this output on the controller would be available for the rotary.
The rotary-unit i want to buy uses a Nema 17 Pancake Stepper-Motor.
