Topwisdom Software usage
Can I use the Lightburn Software 0.9.14 version on a CM1290 80W using a TL-403CB? As a present when connected via USB it can’t find it, but does on my other Machine, Ruida 644XG
Have you tried to set up this controller profile using the ‘Create Manually’ button found in the ‘Devices’ screen? Can you please provide additional details as to what you tried and what results you got?
TopWisdom is officially supported as of the release of version 0.9.10 as stated in the release announcement found here: LightBurn 0.9.10 - Art Library, new capture system, Halftone images, T – LightBurn Software.
TopWisdom controller support
It’s still in progress, but the majority of features are working and stable, so we’re calling TopWisdom support ‘official’. We still have to add rotary support and machine settings, but those are in progress and should be included in the next release.
Is this machine connected to the same computer, or a different one? If a different machine than the one connecting to the Ruida, did you install the FTDI driver suggested on the last page of the LightBurn installer? If not, you’ll likely need that.
