Topwisdom tl-410c laser not turns of between cuts
Hello
help or advise needed,im running lightburn with topwisdom tl-410c controller and if engraving or cutting the laser dose not turn of between moves can someone advise or help plz
Assuming this is new behavior on a machine you’ve had for a while, it’s most likely due to a failing HV power supply that does not shut off correctly, as suggested by the doc:
Buy an HV supply with the same power rating as the tube: a 60 W supply goes with a 60 W tube.
Hello ednisley
Thanks for your reply,i have not long brought the machine and are just getting used to it,with lightburn,allready have a diode and a k40 no problem working them but this is slowly doing my head in his ther anything in machine settings i need to alter will take a few pics if that helps
