I have a Topwisdom TL-A1 on a DIY CO2 laser. I have a problem with motor vibrations and noise when cutting at slow speeds, like 5mm/s. When it runs faster, it goes smoothly.
The drivers are TB6600s on 1/32 micro-stepping. I’ve played with the current settings and with jerk/acceleration, but had no luck with that. The cut is clean, but it still vibrates.
Before this controller, I had it running on Arduino + RAMPS and it worked well at slow speeds, so I don’t think it is a mechanical problem with the axis. Has anyone had similar problems with the TL-A1?
Giving my 2c, if you’re using NEMA17 or similar motors, I firmly believe that the TB660 may be giving them way too much current even at the lowest setting.
Again, if using NEMA17 or similar, a solution would be getting adapters and hooking up TMC2208 or TMC2209 drivers.
